which engine would be better
Discussion in 'HYBRID -> EG-EK / DC' started by weirdman77, Oct 8, 2003.
  1. weirdman77
    weirdman77 Junior Member
    I just wanted to get your oppinion on which engine you would get
    D16 sohc Vtech 125 hp less weight
    or
    Zc dohc non Vtech 129 hp more weight
  2. Frankie P.
    Frankie P. Senior Member
    Austin, TX.
    Neither of those engines exist. I don't know what VTECH is, I thought is was a phone or something.
  3. 96coupeb18
    96coupeb18 Senior Member
    Go with D Series V-tec, you can find more parts for them and cheaper to build up, ZC is old , pretty much only suitable if they are dirt cheap and you are going to put in a CRX.
  4. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    it is VTEC!!! not "V-tec", not "Vtech", not "V-tech".....VTEC!!!
    is that so hard?!?!?!?!
    also, you shold go with the zc. why? it's a DOHC. you have so many more tuning possibilities with a DOHC over a SOHC. but OH NO!! it doesn't have VTEC!!!! SO FUCKING WHAT?!?! all VTEC is is a more aggressive cam lobe for the upper RPM range. so you know what you do? go buy a more aggressive cam! or if you wanna do the cheap thang, buy a set of cam gears.
    VTEC is overrated.
  5. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    I disagree- cause the aftermarket for the ZC is fairly scarce, while it would be hard to find an aftermarket company that doesn't make at least one part for the D16z6- you have tons of options for it- and big deal it's SOHC- go to www.turbod16.com and see what some of those guys are doing with just one cam-
  6. hondahauge
    hondahauge Senior Member
    I would go with the D16 SOHC VTEC
  7. ProspeedCTR
    ProspeedCTR Junior Member
    Somewhere You Wanna Be
    Ummmm you've got it wrong the D16Z6/Y8 makes the same HP and TQ as the ZC. The SOHC VTEC you can find parts for it EVERYWHERE (if you don't believe me come to my house) and the ZC which was not sold here in the U.S. you will catch hell finding parts for it.....You will have more fun with the D16 than the ZC plus you'll have VTEC. ;) I had one in my 89 Civic Hatch DX and LOVED IT now I got a B16A (SiR II) in it and working on putting an H22 in my 95 Civic DX Coupe.
  8. camelian
    camelian Junior Member
    Eh, before my swap, I tried pushing my D16y8 and didn't feel much accel nor VTEC lol. I had to switch between 3rd and 4th on the highway just to keep up with other people. I'm sure it wouldn't be that bad once you do work on it. All I had was a DC Sports header. 96coupe is right, old engines do have their reliability in question.
  9. Jesus Christ
    Jesus Christ Guest
    I would never go with a single cam. I believe single cams are weak! I have spent money on a single cam vtec and all i got out of it was SMOKED! Single cam is like running on one leg compared to dual over head. Sure you can move with one leg but how much faster are you with both legs? Dual over head motors will spank single cams. I am sure that some single cams can beat dual over heads with plenty of money. This is single cam vs. dual over head! :bash:
  10. weak_sauce
    weak_sauce Member
    ahha ownage! :lol: dude why people us Vtech for? i dont get it? simple and easy VTEC!!!
