Which exhaust manifold will fit my cat?? i have a 2000 ex with a jdm engine and jdm exhaust manifold. I dont really want to use the jdm manifold because it wont fit so which other manifold can i use that will fit my 2000 ex cat???
Any b series motor in an ek can use a 99-00 si header and it will bolt right up to your exhaust system. I know cause i had the same question a while back.
i have the 99-00 si manifold right now. only problem i have is my shiftlinkage is rubbing on my o2 sensor at the cat. any ideas on what to do?? btw B18C.
i do have an SI header and yes i do have an o2 sensor before the doughnut gasket. THe problem is i have an o2 sensor at the cat too. OBD2!!
header to exhuast b18c 99 ex so u can use a 99 -00 si b16 header on a b18 and it will match up to the cat on 99 ex coupe
