It's been a while since I did my swap, and I can't remember which USDM gaskets to get for my JDM B16a obd-0... I did some searching but can't really find what I need to know. Which USDM make/model/year in order to fit the JDM B16a? Here's the ones I need: -- Exhaust downpipe gaskets (upper manifold to lower 2-1 downpipe @ flange)? -- Oil pan gasket? -- Valve cover gasket? THANKS _TIM
You most likley cant go wrong with usdm b16 I was thinking the same with mine but for cheaper things I go with teg stuff but oil pan I dont see why you couldnt go with 95 del sol vtec there b16 also with the exhaust
