Which Header to Buy?
Discussion in 'Civic and del Sol - EG and EK' started by Big Shane, Oct 11, 2017.
  1. Big Shane
    Big Shane New Member
    I'm in the beginning stages of doing a very mild build. I've got a 1992 SiR, auto. I plan to purchase a Tanabe Medallion Touring exhaust, mostly because esolsi has the Hyper Medallion & I like the way it sounds. Which header should I purchase to mate up to it? End goal is to put a JRSC to gain a little low end grunt & be able to have some fun when I want to. No plans to change internals unless the supercharger requires it. At the moment the car is completely stock.
    Thanks in advance. 6DE0BF37-FBD8-4110-889E-443752A6F9F2.jpeg B62E44F3-3A2A-432B-B2B4-B8B0309BE232.jpeg
    Briansol likes this.
  2. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    lol the stock one unless you want to get a nice 4-1
  3. BrutalB83
    Rochester Hills, MI
    Where do you live? Here in the states, we never got any B-series cars with automatics besides the non-VTEC Integras and CR-Vs.
  4. Briansol
    it's legit... E and i know shane.
    sisteve had the kamaikaze 4-1 on his JRSC EM1 Si. not sure if those are still around...
    Big Shane likes this.
  5. Big Shane
    I bought it from VistecRImports. I'd like to have gotten a manual transmission, but I had to compromise as the wife doesn't know how to drive stick & I wasn't about to teach her on a RHD vehicle.
  6. Big Shane
    Do some headers work better or worse with a supercharger? I hadn't thought to ask that.
  7. BrutalB83
    Rochester Hills, MI
    Ah, gotcha. Yeah, I was wondering if it was Canadian maybe, but then I realized it was also RHD.
    Bummer on the no manual, but then again, having an auto B-series VTEC does up the rareness factor!
  8. Briansol
    generally, you want the higher flow, so the 'big' ones will work better on a SC'ed set up. The kamikaze has a 2.5" collector as well, so it's good to mate up to a true 2.5" high flow cat and 2.5-3" exhaust as well without the collector being a bottle neck.
    Big Shane, Matts96HB and dilbeckskate like this.
  9. Matts96HB
    Matts96HB . Moderator VIP
    Yeah, I agree with B. Check runner and collector diameters, in general the larger the better with a forced induction setup. Of course there'll be a point of diminishing returns, but I can't imagine anyone is manufacturing a piece that is beyond that point.
  10. phunky.buddha
    Dallas / Fort Worth, TX
    I've got a cut Greddy Evo2 that I need to unload for an EG... it was cut for a new cat when I had to replace mine. Easy to weld the straight part back together or shorten it and then weld.
