Which hub is right?
Discussion in 'Body / Exterior / Interior / Cosmetics' started by BlackFrog, Jan 5, 2004.
  1. BlackFrog
    BlackFrog Neighborhood Lush
    North Freakin' Idaho
    DC2 wheel into EG2 (93 del sol) thats the right wheel to get for that chassis right? will i need the DC2 hub, or will the EG hub be the right one? Also, is this plug and play in terms of the airbag? Or would it be easier to get one without an airbag? im not really worried about the cruise, cuz i never use it... thanks.
    -Chris
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Yes you can use a DC2 steering wheel on a civic/delsol. CTR's do not fit.
  3. BlackFrog
    is that using my hub, or the integra hub? and will all the plugs plug right in?
  4. xj0hnx
    C.C.TX.
    ITR fits like this....disconnect you SRS, unbolt your steering wheel, remove, and replace with ITR steering wheel, pretty simple huh?
  5. BlackFrog
    theres no 'reconnect SRS' in there... what do i do about that?
  6. xj0hnx
    C.C.TX.
    If you have a SRS steering wheel reconnect it, if not then don't.
  7. BlackFrog
    gotcha. just making sure it was gonna plug right in. thanks bud.
