which injectors??
Discussion in 'Forced Induction' started by inspecta83, Oct 16, 2003.
  1. inspecta83
    inspecta83 Senior Member
    ok, here's my setup.... '91 b18b crx, hondata2b, wolbro 255lph fuel pump, and i'll be boosting 10psi (and i kept the crx wiring so its still obd 0 with the resistor box)... i spoke to the peeps at rc engineering and they said that with my set up i would need 370cc peak and hold injectors. does that sound correct as far as size and spec (i.e. peak and hold instead of saturated)?
    also, since i dont have the $300+ to spend on their injectors i wanted to use the injectors from an eclipse since i heard of other people doing this b4 and its cheaper. please let me know what yr/model eclipse injectors i would have to get. i know that since i am using the crx wiring with the resistor box, i would need obd 0 peak and hold injectors. thanks!
  2. pissedoffsol
    how did they give you an answer when you never mentioned what turbo and what horsepower goal you are after?
  3. inspecta83
    i have no idea...thats why im in search of a second opinion....i have a t3/t0e4. as far as an hp goal, i just want the most hp that i can safely get from the above mentioned setup...im guessing probably somewhere around 225-250hp? thanks
  4. pissedoffsol
    i think the peak/hold 450 dsm would suit you well, and run the vafc hack.
    otherwise, 440's and hondata.
  5. inspecta83
    i did a search and read one of your other posts and you said that dsm injectors dont work that great with hondas b/c of their strange impedence or something like that...so, with that in mind, do you think i should just hold out until i could afford the rc's? thanks again.
    http://www.hondaswap.com/forums/index.php?...showtopic=23572
    and here too
    http://www.hondaswap.com/forums/index.php?...showtopic=23718
  6. pissedoffsol
    with hondata, they work like shit
    running the hack, they are fine
  7. inspecta83
    cool...i know this is prob a really basic question but can you just give me a real brief post on what a vafc hack is? i hope this doesnt mean that i just spent $500 on a hondata for nothing.
  8. pissedoffsol
    not at all. hondata owns the hack.
    http://www.thedropshop.tv has aright up on the hack
    you are much better off with the hondata. the hack, is, afterall, a HACK.
  9. inspecta83
    i dunno, maybe im retarded or something so just bare with me...before you said
  10. pissedoffsol
    nope- you got that mixed up.
    if you have hondata, you don't need a VAFC at all. hondata can do everything the vafc can 10x better and then some.
    so,
    option 1-
    VAFC, DSM 450s
    option 2-
    fmu, missing link, stock injectors
    option 3-
    hondata, rc injectors sized to your horsepower goals.
    as for peak/hold vs saturated, it really depends on what ecu you use.
    chances are with hondata, you are going to want to chip the p28, as its the cheapest and most common for a vtec swap, d/b/h series alike. hondata can tune the curves. if you have a gsr with the oem manifold, you realyl "should" get the p72, but thats more $$$ just to have the IAB's working.
    if you run a p28, you want saturated injectors. If there are no sizes availble, you can easily wire in a resitor box to use peak/hold injectors with a p28. hondata.com has a write up on how to do this on their site.
  11. inspecta83
    thanks for clearing that up for me...option 3 is the one for me. i'll be using the peak and hold because i am still using the obd 0 crx engine harness with the resistor box...i am using the PR4 ecu because i have a b18b (LS) which is dohc non-vtec...even thou rc told me that i would be good with the peak and hold 370cc injectors, i think that they would be too small. so the next peak and hold size up from that is the 500cc which is probably what i'll be getting. thanks again for your help on this one.
