which is the better swap
Discussion in 'HYBRID -> ED-EF / DA' started by Bobby17772, Dec 30, 2009.
  1. Bobby17772
    Bobby17772 New Member
    Enfield, CT
    I've been thinking about doing a swap for the spring time that I can still build on over time. I've narrowed it down to the SOHC zc, DOHC zc, and the d15b. I'm not sure which one to get. I know some of you will say just get an LS or b16 but idk I just want to do an easy swap for my first swap. the SOHC zc is still single cam wich means that later on I could do a mini me if I wanted. the DOHC zc is well...a DOHC and thats pretty cool for a d series. And the d15b I'm not sure about it because it's kind of a middle ground. it's vtec which is awesome, and it's more then the SOHC zc but cheaper then the DOHC. if anyone has any input I would love to hear it.
    thanks!
  2. reikoshea
    Dallas, TX
    with your wants, id go sohc zc, mini me later when you can get a z6 head and just have some fun with it.
  3. Bobby17772
    Enfield, CT
    yeah I planed on going turbo with it relatively soon after the swap then I've alwas wanted to hit vtec. but thank you!
  4. 95b16coupe
    95b16coupe New Member
    ct
    vtec is made for fuel economy, lol not "i've got VTACK Y0!!!" vtec should be a smooth transition. if you want to feel a pull, just get the turbo.
  5. Bobby17772
    Enfield, CT
    yeah I know I didn't mean it like that. I meant for the added power and fuel economy. but thank you!
  6. 95b16coupe
    ct
    i've had several turbo'd cars and several honda vtecs. if you save the money you would spend on getting a vtec head, you will be much happier with the turbo results. it will be a minimal difference.
  7. Bobby17772
    Enfield, CT
    well I wanted to in the end do both. first one then the other, I don't really care which one is first
  8. 95b16coupe
    ct
    do the turbo first. if you spend the $600 from going vtec into getting better turbo parts, or even a turbo cam and head job, you will be much happier than adding vtec.
  9. INJEN78
    INJEN78 HS LEGEND
    OHIO
    yea id do the sohc zc then do turbo minime..
  10. vpower
    vpower New Member
    L.A.
    sorry to just into ur thread but i have a 90 si hatch with a sohc zc in it with skunk2 intake manifold and an injen cai...my question is whats a minime???
  11. reikoshea
    Dallas, TX
    sohc non-vtec bottom end with a vtec head.
  12. vpower
    vpower New Member
    L.A.
    gotcha...is that all it is???
  13. Bobby17772
    Enfield, CT
  14. Bobby17772
    Enfield, CT
    they one thing that I'm not sure of with any of these swaps is, they don't really have much of an aftermarket support, like cams, springs valves things like that, well...if I did a mini me it would but besides that, they don't have many unless any of you know of anything
  15. phunky.buddha
    Dallas / Fort Worth, TX
    Yeah they do- just not as easily found as for the B series engines. SOHC D upgrades have been discussed quite often here on Hondaswap. Search it up.
