Which Motor For Power?
Discussion in 'HYBRID -> EG-EK / DC' started by professorjohnfrink, Feb 12, 2003.
  1. professorjohnfrink
    professorjohnfrink Junior Member
    What is a better engine in a 5g civic. For example, would a b18b-turbo or b18c1-turbo (boosted reasonably for a daily driver) be significantly quicker than an n/a h22a with minimal mods, and which setup would be more bang for your buck? I'm guessing that there are more and cheaper after-market mods on the B-series.-Thanks
  2. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    More B-series parts than H-series? No.
    More manufacturers making B-series parts? Yes.
    Cheaper? Sometimes.
  3. Havok
    Havok Senior Member
    Florida
    I wouldn't reccomend cramming an H22A in there if it's a daily driver. I'd go with a B18C1 or B16A Sir II for a fast daily driver. As for cheaper parts, it depends, companies and manufacturers are always competing ,so you just have to look around for a good buy *cough cough ALLJDM and Hybrid Revolution cough cough*
  4. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    well i would reccommend an h22 as a daily driver, it is a haul ass daily driver, and a bad ass drag car...
  5. dohcvtec_accord
    The left lane
    I'd also recommend the H if you don't want to turbo, want a car you can drive every day and don't mind some understeer when taking corners really hard.
  6. brc80
    brc80 Senior Member
    Southern California
    I put i b16 in my 90 teg and its plenty quick for a daily driver.
  7. ekPhred
    ekPhred Senior Member
    I would recommend an H22 as well, especially for an eg. considering those bitches are light as fuck (especially the cx) I had a homie with a gsr eg with bolt ons and it was quick because it didn't have power steering or ac. Imagine how quick it would be with an H22. The power:weight ratio is dope on that chassis, peace!
  8. 92civicvx
    92civicvx Member
    when you talk about understeering explain what you mean. how hard will it be to deal with this cause i want major hp but also want good handling.
  9. E_SolSi
    understeer is also called "plow"... basicly under heavy cornering your car will tend to push straight twards the outside of the turn
    understeer is when the rear of the car is prone to kicking out slightly under hard cornering
    FWD cars are designed with a tendancy to understeer when they exceed their cornering limits
    with the H22 in the engine bay you now have more weight in front of the axles as well as more weight period
    so this will magnify the amount of understeer
    basicy if you were to throw the car into a hard cornering situation the handling would not be sharp and precise... instead you would experience wheel slide similar to trying to corner hard on wet roads
    you can use higher strength springs to compensate for the added weight (batery relocation anf CF hood will help slightly... not nearly as much as people make it seem)2
    the car can be fine as a daily driver... it will only suffer under HARD cornering (autoX, road course, twistie roads.....)
    there are many threads where this has been covered
  10. preluderjs
    preluderjs Senior Member
    san diego
    Go H22 :D . It should be fine for a daily driver, cheaper than going turbo with a B series, and if it stays N/A it should be more reliable than a turbo and easier to maintain.
  11. totalburnout
    NJ
    IMO it really won't suffer.
    Its 80lbs to the front of the car.
    Re-do the suspension and put some good tires on and you really won't notice a difference.
    Think about having a small kid sit on your hood, its not going to make a whole hell of a lot of difference especially if you have an aftermarket suspension and make it distribute the weight.
    just my .02 cents
    i'm a dumbass tho
  12. E_SolSi
    under normal around town/highway driving you are right
    but under hard cornering conditions like autoX, road course racing, or carving through twistie roads you will notice it a lot and it will decrease your handling performance
    for most people this is not an issue .... for me, and the people like me, who are more interested in the cars handling ability than its 1/4 mile acceleration or top speed, this will be a major downside
