Which Motor Is Cheaper To Go To 10's
Discussion in 'Engine Building' started by 91hb, May 27, 2003.
  1. 91hb
    91hb Junior Member
    I'm willing to spend some cash but what I want to know is which motor is better to get to the 10's for street/strip. Which motor is the "cheaper route". I want to go into sleeving and turbo but don't know which motor to get. I already have the b16 but you won't get the torque compare to the b18/b20 motor. Do you recommend h22/h23 swap with turbo or stick with the b16!?
  2. Havok
    Havok Senior Member
    Florida
    10 seconds and street don't go together in a Honda. I think the best bet would be an ITR with bad-ass turbo and nitrous.
  3. pissedoffsol
    if you already have a b16, pick up a b18b bottom end, and get it sleeved to 84mm, and pressped for ls/vtec. then bolt on your b16 head, buy hondata, a full-race turbo kit with a precision sc61 with the .80 stage 5 wheel, a tranny with a limited slip... gsr would work, 24.5x10x13 slicks, and massive weight reduction, and you might run a high 10.
    10s+ street car = good fucking luck.
    motormatrix's 96 hatch put 567 horse to the wheels.... and ran an 11.xxxx
  4. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    Cheap and 10's are two sayings that don't go together very well.
  5. Lyndon S
    Lyndon S Member
    I don't know if anybody has told you this but 10's and streetable don't mix. :lol:
  6. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    do i hear an echo?
  7. JDMilan
    Boca Raton, FL
    yes you do kev.......
    Milan
  8. pissedoffsol
    :lol:
  9. JDMilan
    Boca Raton, FL
    ok, enough............. :p
    Milan
  10. K2e2vin
    Raleigh, NC
  11. hybrid99hatch
    hybrid99hatch Junior Member
    RECIPIE for 10 sec car
    Try buying a cx 92 hatch. gut everything out of it. leave nothing but the seat, steering wheel, and gauges.
    replace glass with fal fiber glass. watch out it scratches.
    now insert H22
    build up pistons, cams, valves, clutch, flywheel etc.
    turbocharger garrett t88
    intercool it
    you will need some sticky tires. slicks preferabally.
    you might be running 11's
    Its not that hard. You can do it for under 20 grand.
    You could drive this on the street but dont make it your daily driver
    just remenber "horsepower to weight ratio"
  12. K2e2vin
    Raleigh, NC
    with that you should be getting 10s, maybe even 9s.
  13. maxeeeman
    maxeeeman Junior Member
    "Cheap" and "10's" = no such thing
    A "cheaper" alternative would be to drop a V-8 in there, or if just want the thrill of 10 seconds get an old muscle car from the 60's. Most of them with just a little bit (cheap) massaging will get you thrills of 10 seconds for "cheaper".
    Yes, I know this forum is all about foreign lovers, but hey, I don't know about much that is foreign and "cheap"
    If you take the word cheap out of this, then we can all get back to discussing our passion with the Honda Engine. :ph34r:
  14. hypnoticzero
    hypnoticzero Junior Member
    :lol: u better stick with running 12/13s range cause maintenace is gonna suck ass if u ahve a 10 s street car specially wehn u race, race fuel dont forget that hgi octane, gonna rebuild the bottom end every couple months, replace clutchs often, too much to worry about go all motor and run 13 :D , best way to go
  15. kyleirwin
    kyleirwin Retired OG
    Vegas
    disregard the post above... he has no idea what he's talking about.
  16. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    I'm going to make an FAQ post on "understanding english"
    when people say cheaper or cheapest it doesn't mean cheap. The word is comparative. please, understand. thank you
  17. blink1_8_2dude
    blink1_8_2dude Senior Member
    10's on a street car this isn't fast and the furious buddy. On a street car the best you will get is low 13's or high 12's.
  18. K2e2vin
    Raleigh, NC
    10s on a street car is possible; using turbo, slicks, weight reduction, some tuning, and living outside of california. i remember there's a 500hp integra with just pistons, rods, itr manifold, ignition, cam gears, and resleeved block that ran 12 flat with slicks and full interior. with more tuning, injectors, and weight reduction im sure that car can bust into the 10s. it was a daily driven car.
