Which Motor? Pls Help!!!
If you are going to do a rebuild, then getting the ITR is a waste considering you are buying it for its higher than normal comp pistons and such. If that is the case, get the gsr. You'll be happier financially, and since you are just replacing the innards you dont have to worry about anything else. Just my $0.02
