which mounts?
lsvteccrx
i recently bought a 97 civic dx and i will be swapping an ls-vtec motor into it. I have done many swaps on integras and civics, but ive never worked with a 96+ civic.
can somebody tell me exactly which mounts i will need?
any info will help. thanks!
Use OEM mounts. There's a reference in our articles section somewhere. Other than that, you should be able to use the same mounts from the 99-00 Si, but I'm not 100% sure.
Yes, you're right. Use all the 99-00 SI mounts and you'll be just fine.
