Which oil feed for turbo?
Where would you get the oil from for a Turbo
  • Oil pressure sensor T-Fitting
    Votes: 0 0.0%
  • Other(Please post suggesti
    Votes: 0 0.0%
  • Total voters
    3
I'd go with the sandwich adapter, but the T fitting is cheaper and just as good.
probably cause im new to ls/ vtech and have only read minimul articles on them
but that golden eagle thing is new to me, but it seems really cool. ive read about tapping two oil holes for ls v tech, and that i geuss eliminates one, one question, where does the t fitting plug into for tubos?? :)
The golden eagle plate goes between the engine and the oil filter. The T-fitting screws (hehe screws) into the engine right next to the oil filter and then the oil pressure sensor and the turbo (or vtec or both :) ) oil line plug into the T-Fitting as well.
flex-a-lite sandwich adapter.
One hole blocked off or used for the return line since it will get pressure to it...but I wouldn't do it.
I've used the flex-a-lite adpater before and has never failed me.
GE is good but kinda expensive.
T fitting works but I wouldn't do that either.
