WHICH ONE
Discussion in 'General Tech and Maintenance' started by 96CIVICLS, May 24, 2005.
  1. 96CIVICLS
    96CIVICLS Senior Member
    MY QUSTION IS WHICH RADIATOR DO YOU THINK WOULD BE BETTER IN A CIVIC WITH A B SERIES ALUMINUM OR COPPER???
    THANKS STEVEO
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    I have a Fluidyne, it's pretty nice....and aluminum. Fact is, any radiator from a EX/SI on up is going to cool a B series fine.
  3. phunky.buddha
    Dallas / Fort Worth, TX
    STEVEO MY ANSWER IS THAT COPPER CONDUCTS HEAT BETTER THAN ALUMINUM BUT ALUMINUM SHEDS HEAT FASTER THAN COPPER SO IF YOU WANT THE BEST COOLING POSSIBLE YOU WANT TO BUY A RADIATOR WITH A COPPER CORE WITH ALUMINUM BONDED TO THE OUTSIDE AND WITH WELDED-IN ALUMINUM FINS IF YOU CAN EVER FIND ONE BUILT THAT WAY IF YOU'RE ABLE TO FIND ONE THEN YOU GET THE BEST OF BOTH WORLDS COPPER TO SUCK AWAY THE HEAT AND ALUMINUM TO TRANSFER IT TO THE SURROUNDING AIR PLUS ALUMINUM CORRODES MUCH SLOWER THAN COPPER AND IT'S HARDER TOO SO YOUR RADIATOR WILL LAST LONGER OK I'M DONE REMEMBER THE CAPS LOCK AND PUNCTUATION NEXT TIME OK!!!
    THANKS MIKE
  4. xj0hnx
    C.C.TX.
    ARRRRGGGHHHHHH
  5. 96CIVICLS
    Sorry bout that. But thats just what i wanted to here Calesta. Thats the best info i seen on here. Right to the point and good info. guess im gonna get the alumunum (can't spell that worth a crap) but thanx alot calesta.
    ya boy steveo
  6. EGProject
    EGProject YEEEEAAHHHHH
    Whitinsville, Massachusetts
