i have read everything on this site current and past post and can not find a 100% answer. It has been sad that the best stock radiator to use is the DOHC del sol. But my question is which radiator will fit the b-series hoses perfectly top and bottom...? I know that you can just clamp the b-series hoses down on the stock radiator but thats not an option for me because i want it to fit the way it was intended to fit...! no chances for leaks or restricting water flow. and if aftermarket is the only way to get this done then which company sound i go with..?
oh yeah and once i get the right radiator for the job then should i use the gsr radiator hoses or the dohc del sol hoses..?
