Which Size Tb Would Be Best
Discussion in 'General Tech and Maintenance' started by dvs_prelude, Mar 20, 2003.
  1. dvs_prelude
    dvs_prelude Senior Member
    I'm looking at Erick's racing TB's but I'm not sure which size to get. I don't plan on boring out my Skunk2 intake manifold at the moment, so that portion will remain 64mm. So with that in mind, which size should I get?
    68-66mm
    70-68mm
    72-70mm
    This is going on a fully built B18C1.
  2. B16
    B16 Super Moderator VIP
    yay area, CA
    how fully built? 72-70mm, if its going to be an all motor monster
  3. dvs_prelude
    P30 pistons stock bore (11:5ish CR)
    ARP rod's/Bolts
    Micropolished and balanced crank
    Portflow head
    Skunk2 IM
    Crower stage 3s
    P28 ECU reprogramed by Erick's Racing :D
    it's pretty much OEM stuff except for the head. I just don't want to pick a TB that's too big for my application.
    So I should get the 72-70mm? Even if I plan on leaving the intake side of the Skunk2 manifold the same 64mm?
  4. 2 litre EG
    2 litre EG Senior Member
    so cali
    try and stick with a 68mm tapered down to 66mm TB... the skunk 2 will only hold up to that much without boring it out [I THINK]... oh and canek, your a biter lmao!!!
    crower stage 3's :p
    all good though, when we gonna line up B)
  5. dvs_prelude
    :lol: biter huh? :rolleyes: I need some good stickies before I line up against you. I'll say by summer I'll be ready. :D Just let me get my TB and header so we can be more even :p
  6. NoJokE
    NoJokE Senior Member
    Sorry to whore your thread, but which TB would be best for turbo? 70mm? The bigger the better?
  7. 2 litre EG
    so cali
    well at least you said sorry lol.... i'd say go with a 70mm
  8. 2 litre EG
    so cali
    pick a race, any race ;p
    Battle - August 9 @ Famoso [might not be able to make it]
    NHRA - September 6 & 7 @ Infineon [Sonoma, Ca.]
    Battle - October 18 & 19 @ Famoso
    NHRA - October 25 & 26 @ Pomona
    IDRC - November 22 & 23 @ LACR
  9. dvs_prelude
    How bout NHRA Oct 25 & 26th @ Pomona... That should give me enough time :D I also plan on going to California Speedway when they open up for summer. I believe it's in May.
