honda_boy911
yeh i guess i will have to see what kinda prices i can get from my guy and see if its that much of a difference... if its only a couple hundred bucks i will go with the GSR
For GSR turbo you might consider a LS tranny---- i have heard with turbo the little bit longer gears are better especially if daily driver
Take a look at the specs of the engines you are considering:
B16A SiR II 1595 170@7600 116@7000 10.4:1
B18B1 1834 142@6300 127@5200 9.2:1
B18C1 1797 170@7600 128@6200 10.0:1
While the C1 has 30 more HP it only has 1 more Torque. The B1 peaks 1000 rpms sooner than the C1 and way sooner than the B16A. The B1 has lower compression so it will respond better to boost and allow you to put more boost in it compared to the C1. My understanding is the only difference between the B1 and C1 is the VTEC head and a longer stroke on the B1. Correct me if I'm wrong, but I believe you get the same performance off the line and only changes with the C1 when the VTEC kicks in. You can still do an LS/VTEC too, but some say not to do that if you are planning on a boost.
Overall I think (if you drive like I do) you will be slightly more satisfied with a B18C1 as you will with a B18B1 unboosted (LS/VTEC is probably the best unboosted). However you will be more satisfied with a B18B1 boosted then you will with a B18C1 boosted. Plus your wallet will be fatter.
Someone more qualified please verify all statements I made. I'm still new enough to be very wrong. Is the SiRII the right B16A engine? I wish we had charts for each stock engine to really compare the numbers.
Since I want to go boost I am seriously looking at the B18B1 and getting it ported and polished before the swap.
Other
From what I read the LS tranny isn't one that is recommended. Most people say to go with a GSR or b16a tranny. I have also gotten conflicting reports and some say that the b16a is better on the 1/4mile while the LS is more fun 0-60. GSR being the best option if you are a no holds bar spend all the money you have type of guy.cool, well i will definatly think of the LS swap.. i can get a complete ls swap for 1300 bucks
Other
Bad head, bad driver, bad tranny, bad tires, bad suspension, bad gas, overconfident, under achiever, VTEC not working properly, needs to be tuned, gremlins, heavier car, etc. There are too many things to consider why you beat a stock B18C1. Based on the performance charts those two engines working and tuned properly in the same car driven by the same driver with the same road conditions will produce a win by the B18C1 every time.i think it's funny my stock JDM B16 beat a stock B18C1, both motors in coupes. consider that
Now the B16a vs the B18b is a toss up stock. If you are using the stock tranny for both then the B16a will win, but using the B16a for both then the B18b will win, but it will be close because of the higher RPM of the B16a. If you turbo both the B18b can take more boost and will quickly overrun the B16a.
I think we can spend days just trying to get the best engine possible for all possibilities and drive ourselves crazy. The fact still remains that with a stock engine the B18C5 is the fastest, but cost the most. B18C1 is the next fastest and is still expensive. B18b is great with boost (can take more because of lower head pressure) and isn't that expensive. B16a is the "standard" tuner engine and therefore has a bunch of aftermarket parts and can be purchased for around the same as the B18b. D16z6 is also a great engine, but not tuned as widely as the B series engines.
If your car came stock with a D16Z6 or a B16A then I wouldn't recommend a swap and just do a rebuild with high performance parts and port the head, but if it didn't then swap to either of those, or if the money is good the B18c. My new goal is to make anyone who buys the Evo X cry that a little civic just schooled them for 1/4 of what it cost them to buy that POS.
Other
EDIT: Maybe I can help an Evo X driver meet a tree at high speeds. Then they will be really crying for years afterwards when they are still having to pay payments on a car they totaled.
