Right now I have no front sway, and there is snow out. Truelly, it is not the bad. It will scare the hell out of you the first few times you spin it, but once you learn how to compinsate for oversteer, it is not that bad.
as for BSQ vs Beaks, they are 2 diffrent designs, however, both work. According to BSQ (he is on honda-tech, and Team-integra.net pretty offten) he has sold over 600 kits, and he has never had a coustomer say that they have ripped there subframe. The beaks is a little more beefier, however, i dont think that it is worth it. I am actually runing the Beaks, and have not had any problems. However, if you plan on running ITR LCA's, dont buy the Beaks, because you have to grind half of the rear bracket off. I did this and a sway bar install took like 5 hours.
If you are going to get the ITR rear sway, you have to buy some LCA's that have holes for the endlinks. What I would do is just go to a junkyard, and take the LCA's and endlinks from any DC integra, VTEC del Sol, or SI hatchback.
