which throttle body gasket??
eg6sir
Supa Mod
VIP
ok.. i need to know which throttle body gasket to buy to run a 64mm throttle body.. i already bought one for the delsol VTEC and i tried using my dremel to shave off some material so it would be big enough, but i'm thinkin that might ruin the gasket.. i know most Honda TBs will fit another motor, but i'm not sure which to use.. i was thinking a ITR gasket would work.. what do you guys think??
the t/b you bought didn't come with a gasket. . . should have.
either way with a 64mm you are gonna have to shave some if you use a honda oem gasket.
take your time with it when you shave it and you should be fine.
its a bored OEM b16 throttle body.. i think i'm gonna use a razor and cut off material while its set up next to the TB..
