Which Transmission?!?!?!?!?!
Discussion in 'Engine Building' started by YangpaNemsay, Nov 12, 2002.
  1. YangpaNemsay
    YangpaNemsay Senior Member
    Okinawa, Japan
    With a 1st gen Integra with a b18c or a b18c5 what transmission would actually fit in the car and which one would work best with the engine itself??? i hear an Integ LS trannys are good for slow revving to keep working vtec longer. WHaT Do i uSe?!?!?!?!
  2. pissedoffsol
    N/A- use the ITR tranny
    trannys all fit i think... its the axels that wont be right...
  3. djextremity
    djextremity Senior Member
    in your rearview mirror..wait..
    dOn'T tYpE LiKe DiS dOoD..
    the 1g integ is a d-series motor, so without a mount kit NOTHING is gonna fit (i think). with a mount kit, however, i don't see why anything won't fit..
  4. bte15
    bte15 Senior Member
    Bellevue, Washington
    if you are planning on turbo get an ls tranny for the longer gears but you generally don't turbo that engine anyway so i would stick with the tranny that you have in there now
  5. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Um he won't be able to run the ITR tranny in a 1st gen teg. Get a J1 cable tranny with an LSD.
  6. [Jett]-CRX
    [Jett]-CRX Member
    Maumelle, AR
    Riiiiggghht... good luck finding one! If you do find a place that has some, let me know... I'd love one!
  7. lsvtec
    So buy the tranny and the LSD seperatly. Or do what I am planning, get a tranny case with no gears in it and buy the Quaiffe gear set for the B16. It will cost a pretty penny, but not much more than a transmission and replacing all the gears from Honda.
  8. B16
    B16 Super Moderator VIP
    yay area, CA
    mmmmmm, quaiffe :)
