Which VW 13" Aluminum Wheels Will Fit a 1985 Honda CRX HF?
Discussion in 'Civic and CRX - EW' started by Ascendedmind, Mar 19, 2016.
  1. Ascendedmind
    Ascendedmind New Member
    Which water cooled Volkswagen 13" Aluminum Wheels Will Fit a 1985 Honda CRX HF, if any?
    & will my 175 70 13" size Toyo tires fit?
    Or which 13" aluminum alloy wheels would you recommend which are lighter than my steel wheels?
    I want to replace my light weight steel wheels with inexpensive aluminum alloy wheels, which I will polish into a mirror like finish.
    My wheels:
    Bolt Pattern: 4 x 100mm
    Backspacing?
    5" Wide
    13" Diameter
    Weight 10 pounds each
  2. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    Need spacers the hub rings are different sizes but like 84+ IIRC
  3. Briansol
    i rocked a set of bulletholes as a winter set. but those were 14's. worked fine.
  4. TurboMirage
    What about BMW bottlecaps
