which wood would be best to use
Discussion in 'Car Audio / Security / Electronic Accessories' started by LudeIntentionz, Mar 7, 2004.
  1. LudeIntentionz
    LudeIntentionz Junior Member
    what type of wood can i use for my subs :ph34r:
  2. D See 2
    D See 2 Senior Member
    Baltimore, MD
    MDF (medium density fiberboard)
  3. driver1
    driver1 Senior Member
    :werd: :withstupid:
  4. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    MDF is the only way to go if you're serious about the performance of your enclosure- i've saved oney using particle board before, and it's sound quality is pretty good but the material is shitty to work with- MDF gets the big :thumbsup:
    oh and seal that fugger good from the inside, leaks suck
  5. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    no if you want tight base use hdf you can use a thiner board and it will be stronger
  6. hondamidnighter
    hondamidnighter Senior Member
  7. lowassaccord
    lowassaccord Senior Member
    ive been installing for about 8 years now mdf is what you want. however it is heavy since you need in my opinion 3/4" thickness, (i prefer 1") there is a type of lightweight mdf which is what i use to build its more expensive but way worth it if you dont want the ass end of your car to sit lower.
  8. EH3B18C
    EH3B18C Banned
  9. Slammed90Lude
    milford, PA
    this guy really wanted to know what wood would be best so :newbie:
  10. hybrid89
    hybrid89 thistownsucks...
    SoCal
    this guy IS a Jackass. MDF all the way. Installed fro 5 years back in the day. only thing I will use. I like 5/8" b/c weight and sound properties.
    matt
  11. EH3B18C
    EH3B18C Banned
    YES! plywood and styrofoam is best, and if you got the money, buy Slammeddudes momma's pussy cum, It makes great resin to seal up that box
  12. hybrid89
    SoCal
  13. EH3B18C
    EH3B18C Banned
    Forget the Dynamat, Get slammedludes poppa's nut sac skin, that shit is the BOMB!
  14. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Or he could just pump your stomach for goat jizz.
  15. Slammed90Lude
    milford, PA
    you're really mature homie, way to go! you've succeeded on a 3rd grade reading level
    :ban: :fuckyou:
  16. pissedoffsol
    our plywood friend has been banned. he's posted useless shit all day.
  17. Smonkeyboy
    Smonkeyboy Senior Member
    Spokane, WA
    i dont see how someone can get so butthurt over dochh22a4 calling his invisible motor bluff.
