Whining noise
Discussion in 'General Tech and Maintenance' started by CIVICTRON, Aug 12, 2008.
  1. CIVICTRON
    CIVICTRON stealthcivic
    The Pas Manitoba
    Just changed timing belt and the car has a whining noise that is sychronized with the cars RPM, meaning as I accelerate the noise gets louder. I noticed after the job my power stearing fluid was low so i topped it up but the noise didnt go away. Anyone know what that noise is caused from and is it safe to drive.
  2. phyregod
    phyregod !!YTINASNI
    Central Texas
    Sounds like its way too flippin tight.
    Is it an OEM timing belt? Cheap ones will also do that.
  3. codyb76
    codyb76 New Member
    Agreed on the timing belt being to tight. No big deal, sometimes it stretches a bit nd quiets up, but ideally you ned to pull the cover and loosen it a bit. I know some of the hondas have a 14mm bolt that can be accessed through the cover that if you loosen it will let the tensioner reset itself using the spring that sets tension on the belt.
  4. CIVICTRON
    The Pas Manitoba
    u mean the bolt in the middle of the cam wheel?
  5. t3t4delsol
    t3t4delsol New Member
    York, Pa
    no the tensioner spring is on the bottom by the crank pully
  6. CIVICTRON
    The Pas Manitoba
    so loosen the bolt on the crank pully
    or tensioner?
  7. t3t4delsol
    York, Pa
    on the tensioner, let it slid down a 1/2" to 1" to make a little more slack in the belt
  8. 91accordwithwork
    91accordwithwork kid that everyone loves!
    Wauwatosa WI
    yah same thing just installed P.S and the beslt for it is whineing alot, thought it was too tight , so i tightend it still doing it , any ideas/?
  9. BrutalB83
    Rochester Hills, MI
    Read much? The answer was right above your post...
    And no thread-jacking please...
  10. phyregod
    phyregod !!YTINASNI
    Central Texas
    Oh, also check the tension on all of your other belts, as you had to remove/replace them while you had the timing belt off, could be coming from one of those, overtightened.
  11. paulsen
    paulsen sponge of knowlege
    sac
    check the outer retaining ring on the crank gear, i had a whine when i changed head gaskets i noticed that it was rubbing because it was on backwards, you never know it might help. im still putting my motor back together hopefully ill be done today and ill let you know if it helped.
  12. paulsen
    sac
    if its installed backwards that is.
  13. whyamionahondaforum
    whyamionahondaforum New Member
    mine was doign the same things, check all belts as was suggessted above. It was my a/c belt
  14. jefffrey0000
    jefffrey0000 New Member
    try to take off the power steering strap then start the car and if you don t hear the noise cause the pompe gonna seeze soon and you can try that with the a/c too
