White smoke
Discussion in 'General Tech and Maintenance' started by WannabeSI, Oct 16, 2003.
  1. WannabeSI
    WannabeSI Senior Member
    Hey i have a freind whos civic is blowing white smoke out of the tail pipe, motor section and vents. overheats as well. vents blow cold. can figure out what is going on. is it the head gasket? what all could it be? radiator fluid is full. i dont know someone help.
    Thanks!
  2. sleepercivic
    sleepercivic Senior Member
    NC Mountains
    most likely head gasket, check your coolant for oil
  3. tab
    tab Super Moderator
    Aberdeen, Washington State
    and your oil for any creamy discoloration. Same idea, just checking the oil for water and coolant. Also, if you are in fact burning water, you will notice your coolant water level dropping over time.
  4. SleEPeR_CRX
    SleEPeR_CRX Senior Member
    Vancouver B.C. canada
    its not oil, b/c oil = blue smoke
    water = white smoke
    so check a water line into the head, or the headgasket. also if its blowing white smoke into the car, its gotta be a line, not ur head gasket.
  5. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    sounds like something's definitely fucked up.
    try the head gasket.
  6. Havok
    Havok Senior Member
    Florida
    that head gasket is gone, my friend.
    Overheating + tons of white smoke = fux0red head gasket...He might want to check for any internal damage.
  7. Bl6CRX
    Bl6CRX Senior Member
    UCLA
    yeah, don't keep drivin it pull that mother off and clean everything up, before you start it again flush out the oil by doing like 3 changes to get all the water out, your bottom end may be ok, but with mater in the rod bearings in such theres a good chance it will sieze on down the road...
  8. jamesA
    Not water, mostly it's the coolant, even though coolant should be a 50/50 mix the white actually comes from the ethynal ...ethanal...(sp?) in the coolant.
    white smoke=coolant
    blue smoke=oil
    Also if you notice puddles of stuff on the ground, stick your finger in it and lick it...if it's really sweet, you're leaking coolant.
  9. zcrex
    zcrex Senior Member
    i'm sure that what my dog (RIP) was tring to do....
    hehehehehehe j/k :ph34r:
  10. arpee79
    arpee79 Senior Member
    I have the same problem,I noticed that it is leaking oil because i took the intake manifold to replace it with TYPE R Manifold(Extra Info) and the gasket was soaked with oil ,It look's to be coming from the valve so either my seals are bad,Valve guides or the VALVE'S.
    SO take the manifolds off just a bit and check for any oil.
    And the smoke im getting is white little blue BUT SMELL'S LIKE UNBURNED GAS.
