the magic bullet theory was/is an attempt to prove that there were 2 gunmen.
not sure if this has been doctored, but i never noticed this before. I always wondered why jackie tries to crawl out the back....
JFK1.wmv‏ - YouTube
I've been spent the last two years proving that Greer, the driver was jfk's real assassin. He fired the shot over his right shoulder resulting in an entrance over the right eye and exit out the right rear.
Thats some grainy UFO quality footage right there.
Right. Play dumb when you have no defense. Greer's left arm crosses confirming the illusion in Zapruder the obvious reality it has always been.
i could see nothing in your little clips that proved anything of what you are saying.
in the clips, i can clearly see that your "gun" is the forehead and hair of the passenger next to the driver reflecting sunlight as he moves forward and back.
nobody is playing dumb here, you obviously missed the whole first page of this "theory" being shot down. (no pun intended)
also....
there is no muzzle flash or recoil visible in that video (unless you REALLY want to see it... in which case you can believe there is anything you want to believe is there)
the "gun" is the sun shining off of the passengers hair
here is a stabilized gif of the important frames
you can clearly see many things in this gif
- you can see the sun shining off of both the driver and passengers heads
- you can see the drivers left hand staying up near the steering wheel
- you can see the drivers white shirt, proving that his left arm did not come across his front like it would have had to in order to aim at JFK's head
- you can see that Connally was leaning across the center of the car into his wife blocking the shot path of a bullet that would have (but clearly did not) come from the drivers location
- you can see that there is indeed NO muzzle flash coming from the "gun"
- you can see that there is no recoil of that "gun"
- the closest thing to a recoil is when the driver turns back around to watch the road and both the driver and passenger duck their heads lower and forward
here is a gif of frames 312 and 313 the kill shot (313) and the frame immediately before the kill shot (312)
- again... sun light reflecting on the tops of the driver and passengers heads
- no gun
- no muzzle flash
- no recoil
also the blood spray pattern is consistent with the shot coming from the rear... the spray goes up and forward then as the car moves forward it blows back... if the shot had come from the front then the spray pattern would have blown up and back with minimal forward splash
id continue debunking this... but quite frankly im sick of watching this man get shot in the head
carry on
oh and here is a high quality still of frame 312
