does any body know where i can get an 11 inch rotor for a 5 lug 91 integra ls... would have made my life easier if it was 4 lug but i dont get lucky like that
As far as I know they never released a 5 lug DA Integra from the factory, at least not in the states. I'm guessing someone swapped a Type R setup onto it.
You're right there was no 5 lug DA Integra over here..
For the OP, you're going to have to figure out what suspension was swapped on your car first. Either that or measure the bolt pattern and find a rotor that fits the bolt pattern & hub size. Plus if you are upgrading rotor size you're going to have to use a different caliper or make/buy a bracket to have everything fit properly.
