why cant i use the hydro tranny?
Discussion in 'HYBRID -> EG-EK / DC' started by electric-boost, Dec 24, 2002.
  1. electric-boost
    electric-boost Member
    cincinnati
    im doing a swap in a 90 teg from b18a to b18c but i wanna know why i cant use the hydro tranny from the b18c do i need a conversion kit? and whats with this ecu junk right now i have a pr4 should i get a pr3, p28, or p72?
  2. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    you can use a hydro trans with a conversion kit.. but i would sell the hydro trans and buy a b16 cable trans... a little shorter 2nd gear and you could come out on top with a little cash for something else
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Hydraulic and cable are use to describe the method by which the clutch is actuated.A cable clutch car doesn't have the equipment to operate or connect to a hydaulic clutch and vise versa,so yes you need a conversion kit.As for your ecu goto the top of the page and check out the reference section on ecu's.
  4. brc80
    brc80 Senior Member
    Southern California
    I wouldl go with the b16 trany as well its great for an all motor app.
