Why does my car have..
Discussion in 'Prelude' started by MthaFuknGreen, Dec 1, 2008.
  1. MthaFuknGreen
    Lodi, CA
    .. a power lock fuse in the underdash fuse box if my car doesnt have power locks?
    and its not just a place to put the fuse, the fuse is actually in there.
    might i have power locks, but just not know it? lol
    there is no lock or unlock button.. but it would be nice to install a keyless entry system.
  2. austin20110
    austin20110 New Member
    Northern Va
    to complete the circut?? maybe
  3. MthaFuknGreen
    Lodi, CA
    well, by that logic.. if a fuse is blown, nothing will work.
    unless you mean the power locks circuit, which would also be redundant if there is no power locks..
  4. austin20110
    Northern Va
    had to look up redundant lol
    trying to look up the fuse box for your car.. you are talking about the 90 prelude si, except all data isnt trying to work right now
  5. MthaFuknGreen
    Lodi, CA
  6. sleeperbb4
    sleeperbb4 New Member
    Most likely just a case of Honda using the same box's on all of their 3rd gens no matter what they're equipped with. Fuse is just there to complete the general fuse box circuit, I'm no electrician, just a guess.
  7. austin20110
    Northern Va
    isnt that pretty much what i said
  8. eg6sir
    its probably to make it easier if you decide to put power locks in it
  9. efhondakid
    Akron-Canton, Ohio
    My hatch has a spot in the fuse block for a sunroof, but my car doesnt have one. No big deal its not going to do anything if the fuse is in or out.
  10. MthaFuknGreen
    Lodi, CA
    i can put power locks in my car?
  11. phyregod
    phyregod !!YTINASNI
    Central Texas
    Yup. Find a donor car and jack the motors/solenoids, brackets, and wiring harnesses. As far as the fuse, someone probably noticed it was missing and popped one in there. Think of it as a spare.
  12. MthaFuknGreen
    Lodi, CA
  13. 1Funryd
    1Funryd Member
    Or you can put in aftermarket ones as well. That might be much easier than finding one with all the motors and stuff. If you did find one, I would just take both doors, much easier to plug in the connectors rather than run the wires thru the doors and into the cab.
  14. MthaFuknGreen
    Lodi, CA
    seriously..
    all id need to do is install the tweeters and other door speakers again.
