Why doesn't my VTEC work?
Discussion in 'HYBRID -> ED-EF / DA' started by 91EDMVTECCRX, Jan 13, 2007.
  1. 91EDMVTECCRX
    91EDMVTECCRX Junior Member
    Germany
    I don't understand why my VTEC isn't working. I'm using the B16 wiring harness, with a PW0 ECU, and I'm even using a Hasport VTEC wiring harness. This swap is in a '91 CRX Si . We couldn't use the Si wiring harness due to different distributor/ignition plugs. Could it be that I have a bum VTEC solenoid?
    I'm getting codes 6 ( Engine Coolant Temperature) and 22 (VTEC Oil Pressure Switch).
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    the pressure switch is the problem make sure there enough oil in the motor
  3. Seany-izzle
    Seany-izzle New Member
    In a fucking house.
    something tells me its not the amount of oil...
  4. AHHVTEC
    Alabama
    yea it might not be the amount of oil but its a good start point to check
  5. red8889sidx
    red8889sidx Banned
    also make sure you wired you knock sensor that makes a big difference also make sure that car temp sensor is also working
  6. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
    code 6 just means you plugged the wrong plug into that white plug on the head.
    code 22 means it's not wired correctly. double check your wiring.
  7. Taco15
    Tallahassee Fl
    the plugs are right above each other. you problaby got them mixed. mkae sure the vtec wire is grounded properly.
  8. 91EDMVTECCRX
    Germany
    Does anybody happen to know what the OEM part number for a Oil Pressure Switch (or the "VTEC Pressure Switch" as its commonly known as)?
  9. Andrew
    Tallahassee, FL
  10. 91EDMVTECCRX
    Germany
    Thanks, but I know about Majestic Honda, as should everybody on this forum, but that's not quite what I asked. I asked what the OEM part number was... not where to get it. The part number (which I stumbled across) is 37250-PR3-003. That's what I was looking for.
    As far as the wiring harness is concerned, the stock Si harness didn't mate up to the swap (why should it?)... it was never meant to be there. It was missing plugs for the intake manifold, and distributor, so it didn't quite "plug right up." I'm utilizing a Hasport harness anyway.
    And lastly, I know I'm running OBD0, and I wouldn't be quite dumb enough to swap out a perfectly running distributor, especially one from anything other than OBD0.
    ...but thanks anyway...
  11. Andrew
    Tallahassee, FL
    I didn't mean to insult your intelligence, but some people have done some retarded things...
    The Si harness will (would have) work just fine on almost any swap, even B series, with the added plugs for vtec, 2nd o2, knock, iat, w/e you need. And I'm not just pulling this out of my butt. My friend here in town(Taco15) is running an LS/VTEC (b16 head) with an Si harness, that I helped wire up, and the car runs great.
  12. Andrew
    Tallahassee, FL
  13. Seany-izzle
    In a fucking house.
    woah woah woah... so you mean its not due to the oil level??? :p
    man i just put in an extra 2qt so my vtec would kick harder... damn.
  14. AHHVTEC
    Alabama
    dude please tell me your kidding, any true honda tec knows if the oil level is to low it will not work...( grasshopper )
  15. bafbrian
    bafbrian New Member
    Atlanta, GA
    I had a similar problem with my car. Since you did a swap on the car, I would have the throttle position sensor checked or the vtec solenoid.
  16. AHHVTEC
    Alabama
    its not a myth yes it has to be a huge dent in just the right spot and yes it has to be very low on oil but it does happen
  17. AHHVTEC
    Alabama
    lol yea i guess your right about that,but it does happen, and hey he was a noob lol and might not check the oil much lol
  18. AHHVTEC
    Alabama
    well i understand but it realy will not work if you have a huge dent were the pick up is, and if its low on oil,rare but it does happen it can be proven but you will risk messing your motor up lol
  19. AHHVTEC
    Alabama
  20. Andrew
    Tallahassee, FL
    lets not get too carried away fellas...
