why is it not runing right
little90
hi i put a b18a in my 90 honda civic with a pr 4 ecu and stayded with the obdo set up it starts but runs like crap and when it warms up it starts to die could some one please help me with this problem
yes oh and i put a pm6 ecu made a big diffrents stil the same code
and whats CEL codes
CEL = Check Engine Light
if you have a CEL, check what codes are coming up.
do a little research man... this site has a ton of info. check out the reference materials for cel codes.
the engine light is on and the code the ECU is popping up is 16 the injectors i just cant figure out what the problem could be ive replaced all the injectors man
help i got a code 16 on my ecu ive check compression its 170 170 170 & 180 Ive change the injectors the main relay the resitor and still cant figure it out its a b18a with obdo componets can someone please help it does start and runs but sputers turns my plugs black like its getting to much fuel what could it be HELP!!!!!!!
