Why is my RPM guage not working?
Discussion in 'Civic and del Sol - EG and EK' started by ktyr5151, Sep 7, 2011.
  1. ktyr5151
    ktyr5151 New Member
    Springfield, VT
    Hey all i have a d16z6 and just recently my rpm guage stopped working. Sometimes it kicks on and then flutters a little and then shuts off. My car is idling perfectly fine with no problems. Any suggestions, thanks.
  2. Rammus
    Rammus New Member
    MN
    I would assume electrical connection or at least that is what it sounds like to me. If the wires or contact points are corroded it would make sense that it may randomly get a decent enough connection to move the needle.
  3. efhondakid
    Akron-Canton, Ohio
    When my alt crapped the bed I would be driving and my tach would stop working. :dunno:
  4. B16
    B16 Super Moderator VIP
    yay area, CA
    I had a bad ground and my tach went crazy.
  5. ktyr5151
    ktyr5151 New Member
    Springfield, VT
    Hmmm. Well thanks for the quick response everybody i appreciate it. I dont think its my alternator cause my battery died today and i had to pop start it and the battery has been fine since. My tach really isnt going crazy at all. It did when i first started to act up like 3 days ago. And after that day it just doesnt work at all. It just sits there at 0 and doesnt move. Every once in a while it might kick on and then die out again. I had a friend tell me that it might be the conection to the crank because thats where he said the sensor was for the rpm guage. Is this true. I honestly have no clue what it could be. Its not a big enough deal to where im freaking out about to get it fixed its just annoying not being able to see my rpm's. Again, Thanks everybody for the quick replies.
  6. ls94civic
    ls94civic New Member
    vermont
    i had problems with my cluster doing the same thing i picked up another cluster and the problem was fixed
  7. ktyr5151
    ktyr5151 New Member
    Springfield, VT
    Where would I check if it were electrical problems or a bad connection?
  8. ls94civic
    vermont
    behind the cluster is a start
  9. ktyr5151
    ktyr5151 New Member
    Springfield, VT
    where is the other conection?
  10. Matts96HB
    Matts96HB . Moderator VIP
    check the wires leading to the distributor
  11. ktyr5151
    ktyr5151 New Member
    Springfield, VT
    Alright ill check that after work today. Thanks for all the help everyone.
  12. B16
    yay area, CA
    RPM signal comes from the distributor not the crank.
  13. bluejcivic
    bluejcivic New Member
    i think you icm is going bad in the dizzy, had it happen to me before
  14. ktyr5151
    ktyr5151 New Member
    Springfield, VT
    What/Where is the icm?
  15. bluejcivic
    small match book sized thing in the dizz, next to the coil, it controls the spark.
    looks like this
    Google Images
  16. ktyr5151
    ktyr5151 New Member
    Springfield, VT
    Would that cause my dizzy to fail? What would happen the icm does crap the bed?
  17. bluejcivic
    it eventually will cause the dizz to die, when it first starts going bad, your tach starts to jump, then it stops jumping and occasionally flickers. its possible its just a corroded lead going to the icm. take it apart and look.. good luck
