why wont my car run
Discussion in 'HYBRID -> EG-EK / DC' started by jdmgsr99civic, Aug 15, 2005.
Thread Status:
Not open for further replies.
  1. jdmgsr99civic
    jdmgsr99civic Junior Member
    okay.. i put in the b18c in my civic coupe about a year ago.. the car has been running great.. the other day i had to take the ignition switch out of it.. when i put the switch back in , the car would not crank.. the switch is working and in correct..
    my question is WHY wont it start??? is it the swap?
  2. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    Apparently it's not working, if it won't start.
    And use a little common sense, dude.
    Your car would start before you removed the ignition switch. After you removed the ignition switch and put it back in, it won't start. It's not fucking rocket science.
    Why would you remove your ignition switch in the first place?
    Holy crap...
  3. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    LMAO ^ :lol:
    Yea, im going to agree;
    Anyways, why don't you try a screwdriver in the switch, maybe the metal pin that goes into the switch broke, and the key turns but the pin isn't turning the switch.
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    This is not Swap-related. This is the Swap-related forum.
    Try again in the right forum.
    :locked2:
Thread Status:
