why...?
Discussion in 'Engine Building' started by sevenhillsbilly, Nov 6, 2008.
  1. sevenhillsbilly
    sevenhillsbilly New Member
    why is high compression like 10:1 so bad for boost when diesels use high compression ratios like 20:1 and still have a turbo on them with out problems?
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    its all in the tune
  3. sevenhillsbilly
    so if i build a motor with a 10:1 compression and boost it with one good tune it would work perfectly fine ?
  4. 95b16coupe
    95b16coupe New Member
    ct
    exactly. ^_^
  5. efhondakid
    Akron-Canton, Ohio
    Its because a diesel engine doesnt have spark plugs to ignite the fuel. Its the compression alone that causes the fuel to combust. That much comp on a gasoline engine will cause detonation and eventually destroy it.
  6. 97hatch
    97hatch ?
    Anderson IN
    diesel fuel is also diffrent than gas you can run HC and boos there was a pro FWD car runing 15.2:1 on about 30lbs of boost but im mot saying whoos car or who tuned it but i say engine being assembled my self
