whymy 1996 honda wont start
spaz716
ok can any tell me y my 1996 honda civic dx wont start it cranks over but it wont start and it sounds like it has no pressure changed the coil in :nuke::nuke:the distributor and timing and dont know whats up with it
if it cranks like there is no pressure then id start by checking the timing
would it fit
does anyone know if my 1996 civic trany would bolt up to a 1993 acur integra engine would like to swap engine :confused:
thanks
more problems with my civic i dont know why itwont start can my cranck position sensor be bad? boutto give up on it
i have a 91 honda civic wagon i just replaced the water pump and lined up timing and still cant get it to start anything to help would be great thanks
When you first turn the key, can you hear the fuel pump priming? If not pump might be out.
first thing to check if it has been running and then decides not to start and has no codes at the ECU:
the main relay
