wich cams?
Discussion in 'Engine Building' started by josuedc2, Mar 27, 2006.
  1. josuedc2
    josuedc2 Senior Member
    Buffalo,N.Y
    Hey,everybody,Im planning to buy stage 2 cams for a b16a with only i/h/e.But I dont know wich are better.Do You guys know? [​IMG]
  2. kaoskustoms
    kaoskustoms Senior Member
    casper wyoming man
    pro skunk2
  3. josuedc2
    Buffalo,N.Y
    do you realy think those are the best for me?
  4. formby
    formby learning in progress
    get some ctr pistons then buy cams...i think if you go with something too big...youll be overcamed ....also rocket cams are the shit...900 bucks for cams and spring set
    http://www.m24x.com/
  5. josuedc2
    Buffalo,N.Y
    skunk2 or m24x? I have to be sure wich are best for me.I dont want to spend lots of money into something cheap. [​IMG]
    are spoon better than skunk2?
  6. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    the best for you right now at this point are Type R cams or at the very most Stage 1 cams. You don't have enough compression to take advantage of anything higher than a stage 1. Just get some ITR or CTR cams. Skunk2 Stage 1 cams would be ok. and with these cams that i mentioned you can get away with using your stock valve train just as long as you DO NOT go past the stock redline of 8200.
  7. josuedc2
    Buffalo,N.Y
    for stage 2,what do I need?more compresion?Iknow i will need to upgrade the valvetrain.
    any more suggestions please email me.
  8. B16RacerN2NR
    Moving back West...
    basically yeah, to fully take advantage stage 2's you'd need, IMO, at least 11.5:1
  9. josuedc2
    Buffalo,N.Y
    already man,thanks for your help [​IMG]
  10. josuedc2
    Buffalo,N.Y
    thanks,but now i want to know if i can put only the CTR intake cam.if so,do i have to make tunning on the timming? [​IMG]
  11. josuedc2
    Buffalo,N.Y
  12. pissedoffsol
    you'll clog it.... if it takes it in, it needs to spit it out too.
    go for a jog. take a straw with you
    you can breathe in through your mouth, but you must exhale through the drinking straw.
    let me know how far you get before you pass out.
  13. josuedc2
    Buffalo,N.Y
    so you think is better to put both of them?
  14. pissedoffsol
    not better, required. IMO of course.
  15. josuedc2
    Buffalo,N.Y
    yo,thanks pissedoffsol.
  16. pissedoffsol
