Ok. Time for the next toy, before I spend the money for an ecu parts, I want to get a Wide Band O2 sensor. Now here comes the question, I've read that you can hook it directly to the ECU and use it just like the normal Narrow Band O2. So is this true, or do I need something to convert it to make it work, and if it can run stand alone, are there any O2's you all recommend? -Gary
