Widest Tires On 89 Crx Si?
Discussion in 'Wheels / Suspension / Tires / Brakes' started by crxsi, Jan 3, 2003.
  1. crxsi
    crxsi Member
    what are the widest tires i can put on my 89 crx si and what would have to be the offset to be able to make this happen. I still want the car to be able to turn without rubbing the wheel well. my rim size im hoping to stay with would be 16 in.
  2. E_SolSi
    dont bother with a 16 inch rim... theres not as good of a tire selection in 16" sizes and you wont be able to fit as wide of a tire... go with a 15"... theyre lighter, and better tires available...
  3. crxsi
    crxsi Member
    thanks for the tip... i was wanting to go with some spoon rims or something somewhat comparable... my main concern is traction to the front wheels
    i think i could squeeze some 215-50r 15's as far as the width goes... but just wanted to know some facts... thanks
  4. sportlinecrx
    sportlinecrx Banned
    the standard 15" tire size for a crx is 195/50 on 15x6.5's. some people have 205/50 on 15x7's but i think 215/50 will probably rub since the sidewall AND the tread are bigger. 215/40's might work if there is such a size. actually, 215/40 would be the standard 16" size.
  5. E_SolSi
    Spoon rims (Spoon anything IMO) are overpriced... and what kind of power are you putting down ... most likely a 205/50/15 with GOOD tires will be more than enough for most setups (not all).. anything more is just added weight that will do nothing but slow you down
  6. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    i think 195 50 15 will be perfect. i know it was on mine.
