xplicitcivic94
When i connect the negative terminal on the battery, my fuel pump primes and gauges cluster comes on as if i turned the key to the on pos. i check all fuses, unplugged the ignition switch harness(both) from under steering column. i unplugged all 3 shock tower plugs. funny thing is, when all 3 are unplugged, the gauge cluster(brake and check engine) lights are still on. when i plug in the 2nd largest, the fuel pump primes. what else should i check?
