If you're a Wii guy, you've probably bought one or all of the first Neo-Geo releases. If you're a Wii guy that has his system connected through component to do progressive scan, you've most likely thrown your 'mote through the screen because your games won't play... as I almost did. Anywho, here's the fix if you haven't found it already: Fire up your Wii and start the VC game. Hit home, go to the Operations Guide, plug in a nunchuck and hit A + Z + 2 simultaneously. You should hear a chime. Hit home and enjoy your Max 330 Mega goodness
