wikipedia
Discussion in 'General Tech and Maintenance' started by Bobby17772, Jul 19, 2009.
  1. Bobby17772
    Bobby17772 New Member
    Enfield, CT
    I guess they really don't check all their facts. I was just looking at the D series engine specs and noticed this little gem
    D16 Series Engines (1.6 Liters)
    [edit] D16A1
    • Found in:
      • 1986-89 Acura Integra (USA)
        • Displacement : 1,590 cc (97 cu in)
        • Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
        • Valvetrain : DOHC (16 valves per cylinder)
        • Fuel Control : OBD-0 MPFI
        • 1986-1987
          • Compression : 9.3:1
          • Power : 113 hp (84.3 kW, 115 ps) @ 6250 rpm
          • Torque : 99 ft·lbf (13.7 kg/m, 134 Nm) @ 5500 rpm
          • Piston Code: PG6
        • 1988-1989
          • Compression : 9.5: 1
          • Power : 120 hp (88.0 kW, 120 ps) @ 6250 rpm
          • Torque: 101 ft·lbf (14.0 kg/m, 137 Nm) @ 5500 rpm
          • Piston Code: P29 (Equivalent to PM7)
          • ECU Code: PG7
    take a look at the valve train, 16 valves per cylinder, that must make some serious power!
