hey guys i have SI seats in my 90-91 crx but a customer wants to know if they will fit in his 89 crx? also will the headlights fit on his 89 crx? thanks.
The seat belt bracket is easy to swap over - the DADs used the 91 on-seat buckle without a problem. They are pre-drilled. And only 1988 has different seatbelts, as far as the floor mount is concerned.
Actually you can use the lights. The only difference is the corner lights. It all depends on what you are working with. The lenses them selves are the same, the mounting brackets are different.
88-89 use slide in corners with 2 screws on the sides
90-91 use slide in corners with 1 screw under the hood
Theres no difference between the fenders except the screw holes for the different years.
