I was wondering if it would work because some Integras(older ones 90-93) mount to the black booster differently. I mean where the two 12mm bolts go through th M/S the right bolt is angled in the upper right of the booster and the left bolt is angled in the lower left of the booster. As where the EG civic bolts are mounted at the exact oppisite angles(Left Bolt high,Right Bolt low). So are 94+ Integra bolts mounted on the booster like the EG or the older Integras? Thanks!
P.S. Is it as easy to change the booster as it is the master cylinder?
