H h22ahatch Junior Member Oct 9, 2003 #1 hey guys ..easy question for some but not for me ..will a 89 crx si tranny bolt up to a 89 hf engine or will i need mods to do so...thanx alot
E EGLSHB Senior Member Oct 9, 2003 #2 will it bolt up? yes..... you will have to use the HF axles, if it is in the HF..... as the outer hubs have a different spline count....
H h22ahatch Junior Member Oct 9, 2003 #3 ok thanx..is there anything else from the hf that i would need for this ?
