When I recieved my B18b1 it didn't come with a Map sensor. Is it possible if i switch the map sensor from my 93 civic CX engine.. and What kind of radiator hose do i use? Will my CX radiator hoses fit the bottom and top? or should i buy the LS hoses and cut them to fit?
if the map sensor is on the throttle body i believe it should but if the map sensor is on the fire wall i think you have to get a new one. pretty sure about this. someone else?
