Will a D16a6 engine/tranny from a 91 si, bolt right in a 95 civic?
Discussion in 'Civic and del Sol - EG and EK' started by camaroguy202002, Apr 13, 2007.
  1. camaroguy202002
    camaroguy202002 I like a challenge.
    Somerset, PA 15501
    Will a D16a6 engine/tranny from a 91 si, bolt right in a 95 civic? thinking of buying the engine/tranny, etc. but don't know if it will fit right in(bolt in engine mounts).?? haven't bought engine yet.
  2. 801CRX
    801CRX Got Rice?
    UTAH
    Yes it should drop right in!
  3. jlicrx
    jlicrx Senior Member
    Colorado Springs
    the engine will bolt in if you swap the mount on the driver's side end of the block - the transmission will not bolt in (mount are different) nor will it work - the 91 transmission has a cable actuated clutch where the 95 Civic has a hydraulic actuated clutch - the 91 engine is OBD0 where the 95 Civic is OBD1, so some wiring changes would need to be done
  4. 801CRX
    801CRX Got Rice?
    UTAH
    ^^^what jlicrx stated is true.
    If I were you I would look into the z6 motor and tranny.
  5. camaroguy202002
    Somerset, PA 15501
    Will my tranny from my motor(d15b7), bolt up to the d16a6 engine?
  6. 9000_red
    9000_red Junior Member
