Will a EF turbo kit fit honda civic 1998 B20
Discussion in 'Civic and CRX - EF' started by 4drteg54321, Mar 29, 2009.
  1. 4drteg54321
    4drteg54321 New Member
    Ok, my friend just gave me his turbo kit off of his b16a honda civic EF. I was wondering will everything fit perfect on my honda civic 1998 b20??
  2. Z6CRX
    Z6CRX übber ɐɾuıu etarip
    Pittsburgh, PA
    short answer, yes
    maybe not perfect, but it would very close. You of course would want to tune it.
    there will likely be some need to trim the bumper or reroute the charge piping. Of course it depends if the manifold has clearance for power steering, ac, and if it sticks out so far it interferes with the radiator.
    effectively you just asked this
    "I have a door, will it fit in my doorway"
  3. Slow&Delirious
    Slow&Delirious isn't fast or furious
    Boonville NC
    like he siad
    It will bolt to your bock, but it wont nessiceraly fit around you engine
  4. 4drteg54321
    ok, well i dont have ps or ac so prolly not gonna worry about that. Am also looking to get a new turbo will any turbo fit or do i have to find a specific one? am lookingg for something that can spool quick but still have little topend.
  5. red91efhatch
    red91efhatch New Member
    Albuquerque
    when it comes to turbos your first question should be how much HP you want (goal) then you go over to turbobygarrett.com and read their turbo 101,102 etc. you will learn how to read compressor maps and understand turbos better, you can then apply the a/r etc to similar turbos to meet your goal if you're not into buying good turbos, although not all turbos are built the same and different manufacturers may/may not have maps for their turbos. also remember your motor (b20) won't handle tons of boost with stock sleeves and although boost numbers shouldn't matter (yet)keep in mind you'll be shooting for 6-10 psi approx 225-270ish HP. you'll probably be looking for something in a 50-57 trim.
    oh and also, you will want a turbo that matches the flange on your manifold, unless you plan on getting a new one if the one on your new turbo is different.
  6. Z6CRX
    Pittsburgh, PA
    sounds like you really shouldn't be playing with cars just yet. Read our FAQ section.. You should be able to find the answer to all your questions regarding this and then some there.
  7. 4drteg54321
    Thanks for the info yeah my goals arent to high just looking for 250whp, am learning as i go. It also my DD.
  8. Slow&Delirious
    Boonville NC
    250 to the wheels is a little bit harder to get to than you think
