Same bore so it fits right? both have 75mm bore, but about 11mm or so different stroke.
https://www.ebay.com/itm/YCP-75mm-D...791053?hash=item51fa6ce34d:g:lIwAAOSwE-lZ93pT
D16Z6
Found in
1992-1995 Honda Civic (ex/si)
1993-1995 Honda Del Sol Si (only USDM)
Displacement : 1590 cm³
Bore and Stroke : 75 mm X 90 mm
Compression : 9.2:1
Power : 125 hp (93 kW) @ 6600 rpm & 106 ft·lbf @ 5200 rpm
Redline : 7200 rpm
Fuel Cut : 7411 rpm
Valvetrain : SOHC VTEC
Fuel Control : OBD-1 MPFI
Head Code : P08
ECU Code : P28
D14A2
Found in:
1995-1996 Honda Civic MA8 (European Market)
Displacement : 1396 cm³
Bore and Stroke : 75.0 mm X 79.0 mm
Compression : 9.2:1
Torque, Power : 117 Nm @ 3800 rpm, 66 kW @ 4800 rpm
Valvetrain : SOHC, 4 valves per cylinder
Fuel Control : Multi-point fuel Injection, PGM-FI
D16Z6
Found in
Compression : 9.2:1
Redline : 7200 rpm
Fuel Cut : 7411 rpm
Head Code : P08
ECU Code : P28
D14A2
Found in:
Compression : 9.2:1
