Will everything fit?
Discussion in 'HYBRID -> EG-EK / DC' started by scottp11, Jul 2, 2005.
  1. scottp11
    scottp11 The Seniorest Member....
    El Paso, TX now, originally from Fresno, CA
    Like the topic says, I got a 93 Civic CX with a D15B8 and the clutch is starting to slip. I got a brand new D16Y8 tranny complete with clutch and everything. I was wondering if everything bolts right up, including axles and shift linkage. I got the shift linkage, but not the axles from the Y8.
    Thanks for all your help! :worthy:
    ...Until the H22/ turbo goes in... :p
  2. E_SolSi
    the tranny will go on fine
    not 100% sure on the axles but they should work fine
  3. scottp11
    Anyone know if the axle's will fit. I don't want to do this tranny swap and find out the axles don't fit... This is my daily driver for now.
    Thanks!!!
  4. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    just pull the halfshafts that are already in your car, and compare. It's like a 2 hour job.
  5. scottp11
    Thanks! I'm gonna try to do this whole tranny swap in a day, so... I'm trying to avoid as much guess work as possible.
    Thank you though!!!
  6. noobvang
    noobvang Senior Member
    Twincities, MN
    If you already got a D'series in there then everything should swap over just like a stock motor.
