Will my wheels fit on this car?
cjvictoria
Active Member
I'm looking at some cars on craigslist right now, and I came across this 1985 300zx... I have some 15x7 rims that fit my crx and they fit the 96 accord so should it fit a 300zx?
The Z is not your bolt pattern. I'd stay away from them unless you have a reliable DD already.
Good point, it was really just a passive curiosity anyways
offset for a rwd car and fwd car are not the same. even if it bolts up, it will look retarded.
Well seeing as most of the DOHC KA are a little newer, then it's better. Newer is better...
I dont even know why im trying to explain this to you.
do you know the difference between single cam kas and dual cam kas ? do you know the difference between s13 kas and s14 kas ? what about newer makes it better ? if you know anything about ka24des , they die of top end failure, pretty much all of them do, or failed oil pumps, the single cam slammers make a little less hp, but are pretty much bulletproof, dont know why your trying to dis me when I seriously have quite a bit of knowledge base on the nissan ka engine
Just shut the fuck up asshole, nobody asked you about the differences. Can we please ban this asshat? FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFUUUUUCCKKK YOU
