Will Obd1 Dist. From '93 Ls Work On A B16?
Discussion in 'HYBRID -> EG-EK / DC' started by nuc79, Jan 15, 2003.
  1. nuc79
    nuc79 Senior Member
    SE Georgia (near Jacksonville, FL)
    I got this 93 integra LS obd-1 distributor with Bosch red plug wires off eBay for $21.50 minus ignitor and coil. It just so happens that I have an NEC ignitor and TEC internal coil from a 93 Si dizzy that had a bad bearing. Will this unit work on a B16a1 being converted to OBD-1? Thanks in advance.
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    From what I was told,when I was looking for a distibutor.As long as it is B series and OBD 1 it should fit.
  3. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Yes, iff you cut one leg off the disrtibutor from the LS it will fit the B16 head. I ran my LSVTEC like this for a few days until the Acura dealer got me a replacement ignitor for the 94 GSR distributor I had. However, setting your timing with that LS distributor is tough. I think I had to run 19 degrees advanced with it because that was as delayed as it would go. You would be better off getting a 93-95 GSR or the OBD1 Del Sol VTEC distributor.
