Will Si harness work on STD?
justjeff
Ok, I'm doing a b16 swap into a 90 std hatch. I noticed that i have a crx si harness laying around..can i use it to avoid dpfi to mpfi hassle? also, my b16 comes w/ vss instead of cable driven..how can i convert that or should i get a gauge that use vss?
Jeff-
you cannot use the SI harness, you have to perform the MPFI conversion
take the electric VSS out of the b16 tranny, its 1 10mm bolt, and swap it with the mechanical speedo sensor from your old d-series tranny
